Salta al contenuto principale
MSI GE62 Apache Pro 004 Motherboard Replacement
Cosa ti serve
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: passo 2, immagine 1 di 2 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: passo 3, immagine 1 di 3 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 3, immagine 2 di 3 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: passo 5, immagine 1 di 3 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 5, immagine 2 di 3 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 5, immagine 3 di 3
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Conclusione
Alexander
Membro da: 02/19/18
86 Reputazione
1 Guida realizzata
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro di USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Membri
5 Guide realizzate
Un commento
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,012
