Salta al contenuto principale
MSI GE62 7RD RAM Replacement
Cosa ti serve
  1. MSI GE62 7RD RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Flip the laptop over so that the bottom is on top.
    • Caution: make sure the laptop is fully powered off (not sleep mode) and not connected to the AC charging adapter before beginning the repair.
  2. MSI GE62 7RD RAM Replacement: passo 2, immagine 1 di 2 MSI GE62 7RD RAM Replacement: passo 2, immagine 2 di 2
    • Remove the fifteen 6.5 mm Phillips #0 screws from the bottom of the laptop using a Phillips #0 screwdriver.
    • Be sure to remove the two screws in the middle of the laptop, they're easy to miss! They might be under a factory seal label.
  3. MSI GE62 7RD RAM Replacement: passo 3, immagine 1 di 2 MSI GE62 7RD RAM Replacement: passo 3, immagine 2 di 2
    • Remove the back case from the laptop.
    • If the backing is really stuck, you may use a plastic opening tool or picks to provide leverage.
  4. MSI GE62 7RD RAM Replacement: passo 4, immagine 1 di 2 MSI GE62 7RD RAM Replacement: passo 4, immagine 2 di 2
    • With both thumbs, pull the silver overhangs on the sides of the RAM until the old stick of RAM pops up.
  5. MSI GE62 7RD RAM Replacement: passo 5, immagine 1 di 1
    • Remove the old stick of RAM by pulling back and out.
  6. MSI GE62 7RD RAM Replacement: passo 6, immagine 1 di 2 MSI GE62 7RD RAM Replacement: passo 6, immagine 2 di 2
    • Place the new stick of RAM in the socket so that the electrical contacts match.
    • Push the top of the stick of RAM down and in until you hear the click of the silver overhangs latch onto the RAM.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 53
Tutti i Tempi: 1,067
