Salta al contenuto principale
MSI GE62 6QF Apache Pro RAM Replacement
Cosa ti serve
  1. MSI GE62 6QF Apache Pro  RAM Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro  RAM Replacement: passo 2, immagine 1 di 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro  RAM Replacement, Bottom Case: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro  RAM Replacement: passo 4, immagine 1 di 3 MSI GE62 6QF Apache Pro  RAM Replacement: passo 4, immagine 2 di 3 MSI GE62 6QF Apache Pro  RAM Replacement: passo 4, immagine 3 di 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro  RAM Replacement: passo 5, immagine 1 di 2 MSI GE62 6QF Apache Pro  RAM Replacement: passo 5, immagine 2 di 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro  RAM Replacement, Battery: passo 6, immagine 1 di 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: passo 6, immagine 2 di 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: passo 6, immagine 3 di 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro  RAM Replacement, RAM: passo 7, immagine 1 di 2 MSI GE62 6QF Apache Pro  RAM Replacement, RAM: passo 7, immagine 2 di 2
    • Pull the metal tabs that hold the RAM in place away horizontally from the RAM stick, and slide the RAM out of the socket.
    • Repeat the same steps for the other RAM stick.
Conclusione
Juan Erquiaga
Membro da: 09/26/17
107 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G3, Passmore Fall 2017 Membro di USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 75
Tutti i Tempi: 2,268
