Salta al contenuto principale
MSI Force GC30 V2 D-Pad Replacement
Cosa ti serve
  1. MSI Force GC30 V2 D-Pad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
  2. MSI Force GC30 V2 D-Pad Replacement: passo 2, immagine 1 di 3 MSI Force GC30 V2 D-Pad Replacement: passo 2, immagine 2 di 3 MSI Force GC30 V2 D-Pad Replacement: passo 2, immagine 3 di 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
  3. MSI Force GC30 V2 D-Pad Replacement, Vibration Motor: passo 3, immagine 1 di 3 MSI Force GC30 V2 D-Pad Replacement, Vibration Motor: passo 3, immagine 2 di 3 MSI Force GC30 V2 D-Pad Replacement, Vibration Motor: passo 3, immagine 3 di 3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
  4. MSI Force GC30 V2 D-Pad Replacement, D-Pad: passo 4, immagine 1 di 3 MSI Force GC30 V2 D-Pad Replacement, D-Pad: passo 4, immagine 2 di 3 MSI Force GC30 V2 D-Pad Replacement, D-Pad: passo 4, immagine 3 di 3
    • Remove the 7.1 mm-long screw with a Phillips screwdriver.
    • Remove the 7 mm-long screw with a Phillips screwdriver.
    • Carefully lift the motherboard out of its housing.
  5. MSI Force GC30 V2 D-Pad Replacement: passo 5, immagine 1 di 3 MSI Force GC30 V2 D-Pad Replacement: passo 5, immagine 2 di 3 MSI Force GC30 V2 D-Pad Replacement: passo 5, immagine 3 di 3
    • Remove the rubber button membrane from the motherboard.
  6. MSI Force GC30 V2 D-Pad Replacement: passo 6, immagine 1 di 3 MSI Force GC30 V2 D-Pad Replacement: passo 6, immagine 2 di 3 MSI Force GC30 V2 D-Pad Replacement: passo 6, immagine 3 di 3
    • Remove the D-pad from the front case.
  7. MSI Force GC30 V2 D-Pad Replacement: passo 7, immagine 1 di 2 MSI Force GC30 V2 D-Pad Replacement: passo 7, immagine 2 di 2
    • Optional: Remove the D-Pad end cap from D-Pad button.
    • The included alternate D-Pad end cap can be reattached after reassembling the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 718
