Introduzione
In this guide we are replacing the ABXY button from the MSI FORCE GC30 V2; the model number/name: MSI FORCE GC30 V2. The ABXY button are one of the main buttons on the layout of the controller. All games utilize these buttons as they are used to control a characters action. There are a few symptoms of a faulty ABXY button that is in need of replacement. One symptom users experience is button jamming, its when the user presses one of the ABXY buttons and it does not pop back up to its original position. Another symptom is no input is received when you press one of the ABXY buttons.
Cosa ti serve
Puncture the sticker where indicated using a screwdriver.
Remove the 9.1 mm-long Phillips #0 screw.
Remove the remaining six 9.2 mm-long Phillips #0 screws with a Philips #0 screwdriver.
Use tweezers to grip the white battery connector.
Pull the battery connector directly out of its port.
Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
Carefully remove both the right and left vibration motors from their housing.
Remove the 7.1 mm-long Phillips #0 screw.
Remove the 7 mm-long Phillips #0 screw.
