Salta al contenuto principale
MAGNAVOX MDV2300 Power Cord Replacement
Cosa ti serve
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: passo 2, immagine 1 di 1
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: passo 3, immagine 1 di 1
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: passo 4, immagine 1 di 1
  5. MAGNAVOX MDV2300 Power Cord Replacement: passo 5, immagine 1 di 2 MAGNAVOX MDV2300 Power Cord Replacement: passo 5, immagine 2 di 2
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: passo 6, immagine 1 di 1
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: passo 7, immagine 1 di 1
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
Conclusione
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
Justin
Membro da: 01/21/15
298 Reputazione
2 Guide realizzate
Penn State, Team 1-41, Kaschak Winter 2015 Membro di Penn State, Team 1-41, Kaschak Winter 2015
PSU-KASCHAK-W15S1G41
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 534
