Salta al contenuto principale
M3t Kiosk Preventative maintenance
  1. M3t Kiosk  Preventative maintenance, Handle and Lock: passo 1, immagine 1 di 1
    • Make sure the door lock and handle are in good working order and not bent or loose
  2. M3t Kiosk  Preventative maintenance, Opt cords: passo 2, immagine 1 di 2 M3t Kiosk  Preventative maintenance, Opt cords: passo 2, immagine 2 di 2
    • Check the opt cords to make sure they aren’t broken or crimped
  3. M3t Kiosk  Preventative maintenance, Opt Lights: passo 3, immagine 1 di 1
    • Make sure all the opt box lights that are supposed to be on are on.
  4. M3t Kiosk  Preventative maintenance, Dispenser Belts: passo 4, immagine 1 di 2 M3t Kiosk  Preventative maintenance, Dispenser Belts: passo 4, immagine 2 di 2
    • Clean belts on top and on the back of the dispenser.
  5. M3t Kiosk  Preventative maintenance, Test Dispense: passo 5, immagine 1 di 3 M3t Kiosk  Preventative maintenance, Test Dispense: passo 5, immagine 2 di 3 M3t Kiosk  Preventative maintenance, Test Dispense: passo 5, immagine 3 di 3
    • Test dispense the coin hoppers and the cash dispenser
  6. M3t Kiosk  Preventative maintenance, Test Dispense (continued): passo 6, immagine 1 di 2 M3t Kiosk  Preventative maintenance, Test Dispense (continued): passo 6, immagine 2 di 2
    • (Continued)
  7. M3t Kiosk  Preventative maintenance: passo 7, immagine 1 di 1
    • Check the coin hoppers to make sure nothing is in it other than coins (like rubber bands or something that was dropped in it)
  8. M3t Kiosk  Preventative maintenance, Fans: passo 8, immagine 1 di 2 M3t Kiosk  Preventative maintenance, Fans: passo 8, immagine 2 di 2
    • Clean any dust off of the fans
  9. M3t Kiosk  Preventative maintenance, Printer: passo 9, immagine 1 di 1
    • Check the printer for paper and put in more if it's needed
  10. M3t Kiosk  Preventative maintenance: passo 10, immagine 1 di 2 M3t Kiosk  Preventative maintenance: passo 10, immagine 2 di 2
    • Open and blow out the printer to remove any loose paper
  11. M3t Kiosk  Preventative maintenance, Clean Bill Validator: passo 11, immagine 1 di 1
    • Run a cleaning strip through the BV
  12. M3t Kiosk  Preventative maintenance, Bill Validator board: passo 12, immagine 1 di 1
    • Check for coins on the BV board.
  13. M3t Kiosk  Preventative maintenance, Bill Validator protector: passo 13, immagine 1 di 1
    • Put a board protector on if it’s missing and you have one available
  14. M3t Kiosk  Preventative maintenance, Screen cleaning: passo 14, immagine 1 di 1
    • Clean the touch screen
  15. M3t Kiosk  Preventative maintenance, Door lights: passo 15, immagine 1 di 1
    • Check to see if the door lights are on and working
Conclusione
Altre 2 persone hanno completato questa guida.
Timothy Morse
Membro da: 12/30/15
1.198 Reputazione
6 Guide realizzate
The Curo Group Membro di The Curo Group
Community
2 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 446
