Salta al contenuto principale
M3D Micro Z Axis Belt Replacement
  1. M3D Micro Z Axis Belt Replacement, M3D Micro Frame Removal: passo 1, immagine 1 di 1
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Z Axis Belt Replacement: passo 2, immagine 1 di 3 M3D Micro Z Axis Belt Replacement: passo 2, immagine 2 di 3 M3D Micro Z Axis Belt Replacement: passo 2, immagine 3 di 3
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
  3. M3D Micro Z Axis Belt Replacement: passo 3, immagine 1 di 2 M3D Micro Z Axis Belt Replacement: passo 3, immagine 2 di 2
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
  4. M3D Micro Z Axis Belt Replacement, Z Axis Belt: passo 4, immagine 1 di 3 M3D Micro Z Axis Belt Replacement, Z Axis Belt: passo 4, immagine 2 di 3 M3D Micro Z Axis Belt Replacement, Z Axis Belt: passo 4, immagine 3 di 3
    • Remove the z axis belt from the device by simply lifting each corner of the belt off the corner gears and slide up over the z axis bars.
Conclusione
USF Tampa, Team S3-G2, Nance Fall 2017 Membro di USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Membri
10 Guide realizzate
1Commento della guida
Need a replacement z axis belt for my M3D micro printer don’t know where to go to get one
Ramon Arguello - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,284
