Salta al contenuto principale
M3D Micro Motor Replacement
Cosa ti serve
  1. M3D Micro Motor Replacement, M3D Micro Frame Removal: passo 1, immagine 1 di 1
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Motor Replacement: passo 2, immagine 1 di 3 M3D Micro Motor Replacement: passo 2, immagine 2 di 3 M3D Micro Motor Replacement: passo 2, immagine 3 di 3
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
  3. M3D Micro Motor Replacement: passo 3, immagine 1 di 2 M3D Micro Motor Replacement: passo 3, immagine 2 di 2
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
  4. M3D Micro Motor Replacement, Motor: passo 4, immagine 1 di 1
    • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
  5. M3D Micro Motor Replacement: passo 5, immagine 1 di 2 M3D Micro Motor Replacement: passo 5, immagine 2 di 2
    • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
  6. M3D Micro Motor Replacement: passo 6, immagine 1 di 2 M3D Micro Motor Replacement: passo 6, immagine 2 di 2
    • Once disconnected you will proceed to lift the motor using pliers.
  7. M3D Micro Motor Replacement: passo 7, immagine 1 di 2 M3D Micro Motor Replacement: passo 7, immagine 2 di 2
    • Now, remove the motor.
Conclusione
Miguel Pina
Membro da: 10/17/17
122 Reputazione
1 Guida realizzata
USF Tampa, Team S3-G2, Nance Fall 2017 Membro di USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Membri
10 Guide realizzate
1Commento della guida
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,870
