Salta al contenuto principale
Lytro Camera First Generation Repair
Cosa ti serve
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: passo 1, immagine 1 di 1
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: passo 2, immagine 1 di 1
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: passo 3, immagine 1 di 1
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: passo 4, immagine 1 di 1
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: passo 5, immagine 1 di 1
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: passo 6, immagine 1 di 1
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: passo 7, immagine 1 di 1
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: passo 8, immagine 1 di 1
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: passo 9, immagine 1 di 1
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: passo 10, immagine 1 di 1
    • Now that you have it off you can replace it and reverse the steps getting it back together.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 392
