Salta al contenuto principale
Lumen Projector Bulb Replacement
Cosa ti serve
  1. Lumen Projector Bulb Replacement, Unplug projector: passo 1, immagine 1 di 1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Lumen Projector Bulb Replacement: passo 2, immagine 1 di 1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Lumen Projector Bulb Replacement: passo 3, immagine 1 di 1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Lumen Projector Bulb Replacement: passo 4, immagine 1 di 1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Lumen Projector Bulb Replacement: passo 5, immagine 1 di 1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Lumen Projector Bulb Replacement: passo 6, immagine 1 di 1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Lumen Projector Bulb Replacement: passo 7, immagine 1 di 1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Lumen Projector Bulb Replacement: passo 8, immagine 1 di 1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Lumen Projector Bulb Replacement: passo 9, immagine 1 di 1
    • Dispose of the bulb by sending it to a recycling center.
Conclusione
Desiree Benitez
Membro da: 01/21/17
128 Reputazione
1 Guida realizzata
Un commento
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 761
