Salta al contenuto principale
Lubricate General Electric Telephone 2-9710A Tuning Slider
Cosa ti serve
  1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Phone Cord: passo 1, immagine 1 di 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Phone Cord: passo 1, immagine 2 di 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Lubricate General Electric Telephone 2-9710A Tuning Slider: passo 2, immagine 1 di 3 Lubricate General Electric Telephone 2-9710A Tuning Slider: passo 2, immagine 2 di 3 Lubricate General Electric Telephone 2-9710A Tuning Slider: passo 2, immagine 3 di 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Lubricate General Electric Telephone 2-9710A Tuning Slider, 9V Base Battery: passo 3, immagine 1 di 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, 9V Base Battery: passo 3, immagine 2 di 2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Volume Dial: passo 4, immagine 1 di 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Volume Dial: passo 4, immagine 2 di 2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Screws on the Back: passo 5, immagine 1 di 1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Lubricate General Electric Telephone 2-9710A Tuning Slider, Pry the Back Off: passo 6, immagine 1 di 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Pry the Back Off: passo 6, immagine 2 di 2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. Lubricate General Electric Telephone 2-9710A Tuning Slider, Lubricate General Electric Telephone 2-9710A Tuning Slider: passo 7, immagine 1 di 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Lubricate General Electric Telephone 2-9710A Tuning Slider: passo 7, immagine 2 di 2
    • Turn the tuning slider counterclockwise until the slider stops.
    • Apply lubricant to the slider rail.
    • Turn the tuning slider back and forth to distribute the lubricant.
    • Make sure the lubricant does not touch the circuit board. This can damage the circuit board.
Conclusione
Alles Rebel
Membro da: 09/20/12
72 Reputazione
3 Guide realizzate
Cal Poly, Team 16-59, Forte Fall 2012 Membro di Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 799
