Introduzione
This is a three part Lower Unit Service on a Johnson 40 boat motor. Model Number: J40ELERE
Cosa ti serve
Remove the cotter pin that is stuck through the propeller shaft using a pair of pliers.
If the washer behind the propeller did not come off with the propeller, remove it and set it aside with the propeller, other washer, and castle nut.
Remove upper cowl by turning the black levers on the front and rear of the cowl
Altre 2 persone hanno completato questa guida.
