Introduzione
In this tutorial I will tell you how you can disassemble your Ursa Nano 1st gen
Cosa ti serve
Okay, so basically you have to peel off this sticker (use hair dryer because otherwise you can damage this sticker).
Next you have to unscrew two tiny screws to loosen the base and electronics inside
Now we start the hardest part. You need to push the electronics out through the USB port located at the bottom, using thin tweezers or a needle. (BE CAREFUL IF YOU USE AN ITEM THAT IS TOO THICK, YOU MAY BREAK THE CHARGING PORT)
Congratulations, you've taken apart your inhaler. Now make any necessary repairs and follow the steps in reverse to put it back together
