Salta al contenuto principale
Lorex MC6950 Camera Lens Replacement
Cosa ti serve
  1. Lorex MC6950 Camera Lens Replacement, Camera Lens: passo 1, immagine 1 di 2 Lorex MC6950 Camera Lens Replacement, Camera Lens: passo 1, immagine 2 di 2
    • To remove a bad lens, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
  2. Lorex MC6950 Camera Lens Replacement: passo 2, immagine 1 di 2 Lorex MC6950 Camera Lens Replacement: passo 2, immagine 2 di 2
    • Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
    • Once the camera is removed, remove the wires from the outer containment shell.
    • Be careful. The metal spudger could damage the camera if not handled with care.
  3. Lorex MC6950 Camera Lens Replacement: passo 3, immagine 1 di 2 Lorex MC6950 Camera Lens Replacement: passo 3, immagine 2 di 2
    • With the camera in hand, the circuit board must be separated from the LED containment shell. There is a 5mm JIS 0 screw at every corner of the circuit board.
    • The wires attaching the circuit board to the shell should be removed as well.
  4. Lorex MC6950 Camera Lens Replacement: passo 4, immagine 1 di 1
    • Now the motor housing must be removed from the circuit board first as it is in the way of the screws associated with the lens. There are three 5mm JIS 0 screws located on the lens side of the circuit board to remove the motor.
  5. Lorex MC6950 Camera Lens Replacement: passo 5, immagine 1 di 1
    • The lens has two 5 mm JIS 0 screws located under the motor's previous location. Once these are removed, the lens can be replaced.
Conclusione
Elijah Conlin
Membro da: 11/07/17
379 Reputazione
3 Guide realizzate
IUPUI, Team S2-G2, Harley Fall 2017 Membro di IUPUI, Team S2-G2, Harley Fall 2017
IUPUI-HARLEY-F17S2G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 821
