Salta al contenuto principale
Lorex LW2742 Speaker Replacement
Cosa ti serve
  1. Lorex LW2742 Speaker Replacement, Back Panel: passo 1, immagine 1 di 3 Lorex LW2742 Speaker Replacement, Back Panel: passo 1, immagine 2 di 3 Lorex LW2742 Speaker Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 Speaker Replacement: passo 3, immagine 1 di 2 Lorex LW2742 Speaker Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 Speaker Replacement, Speaker: passo 4, immagine 1 di 3 Lorex LW2742 Speaker Replacement, Speaker: passo 4, immagine 2 di 3 Lorex LW2742 Speaker Replacement, Speaker: passo 4, immagine 3 di 3
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 Speaker Replacement: passo 5, immagine 1 di 2 Lorex LW2742 Speaker Replacement: passo 5, immagine 2 di 2
    • Using a metal spudger, pry the melted black plastic away from the speaker.
    • Carefully pull the speaker out of its housing by the wires.
Conclusione
USF Tampa, Team 16-1, Eyestone Fall 2016 Membro di USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 208
