Salta al contenuto principale
Lorex LW2742 Lens Replacement
Cosa ti serve
  1. Lorex LW2742 Lens Replacement, Lens: passo 1, immagine 1 di 2 Lorex LW2742 Lens Replacement, Lens: passo 1, immagine 2 di 2
    • Remove the six 10mm Torx T10 screws on the camera face.
  2. Lorex LW2742 Lens Replacement: passo 2, immagine 1 di 1
    • Remove the exterior lens cover.
  3. Lorex LW2742 Lens Replacement: passo 3, immagine 1 di 3 Lorex LW2742 Lens Replacement: passo 3, immagine 2 di 3 Lorex LW2742 Lens Replacement: passo 3, immagine 3 di 3
    • Remove the foam ring around the lens with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Lens Replacement: passo 4, immagine 1 di 1
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the top and bottom 5mm screws first, followed by the left and right 8mm screws.
  5. Lorex LW2742 Lens Replacement: passo 5, immagine 1 di 1
    • Remove the LED board with tweezers.
    • It is unnecessary to unplug the LED board from internal components for lens replacement.
  6. Lorex LW2742 Lens Replacement: passo 6, immagine 1 di 2 Lorex LW2742 Lens Replacement: passo 6, immagine 2 di 2
    • Use the Phillips #000 to remove the three 3mm screws on the face of the camera lens
  7. Lorex LW2742 Lens Replacement: passo 7, immagine 1 di 1
    • Remove the camera lens.
    • After replacing camera lens and before reassembly it is encouraged to clean new lens surface with a microfiber lens cleaning cloth
Conclusione
USF Tampa, Team 16-1, Eyestone Fall 2016 Membro di USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 897
