Cosa ti serve
This little camera comes with the LHA4000 kit by Lorex.
It has a 4K sensor with motion sensor and infrared lights
Remove the 4 screws holding down the camera lens. They are standard Philipps #1
The system board is directly attached to the back of the lens.
The connector is a simple 4 wires. This make it very easy to repair.
There is a rubber grommet that keep moisture away from the inside of the board.
There IS also this sillica pack inside the camera if moisture ever breach in.
The base is fixed to the feet using a single Phillips #1 screw
Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
3 Commenti
Can you do disassembly video on Lorex C861MB camera ?
Can you do a disassembly video on Lorex C861MB camera ?
How much is this camera
