Introduzione
The Seahorse Pro and Seahorse Pro Plus electric nectar collector devices, are a type of dab pen vaporizer made by Lookah.
Sometimes after cleaning the Seahorse Pro or Pro Plus device, you may get a flashing yellow light.
If the indicator light flashes yellow 5 times when you press the power button, then this indicates an open circuit problem.
This can be if the tip or cartridge isn't on correctly or if it was screwed on too tight.
If cleaning the device doesn't resolve the issue then you can try to adjust the pin as shown in this guide.
Panoramica video
Remove the coil from the vape device by unscrewing it anticlockwise
Tighten it up then unscrew the pin about 1 to 1.5 turns.
Do not remove the pin fully,
If you still get the yellow light adjust the pin a little further.
Altre 5 persone hanno completato questa guida.
2Commenti sulla guida
Tks! Worked perfectly.
Thanks for this guide it works.
