Salta al contenuto principale
Longboard or Skateboard Truck Maintenance
Cosa ti serve
  1. Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: passo 1, immagine 1 di 2 Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: passo 1, immagine 2 di 2
    • Use a Phillips/flat head screw driver, along with a skate tool or set of pliers, to loosen the nuts which fasten the trucks to the deck.
  2. Longboard or Skateboard Truck Maintenance: passo 2, immagine 1 di 1
    • Use your fingers to fully loosen and remove the nuts from the bolts.
    • Nuts are small and easy to lose track of.
  3. Longboard or Skateboard Truck Maintenance: passo 3, immagine 1 di 3 Longboard or Skateboard Truck Maintenance: passo 3, immagine 2 di 3 Longboard or Skateboard Truck Maintenance: passo 3, immagine 3 di 3
    • Use your hands to remove the trucks from the deck.
    • Make sure the kingpin is facing outward, If the kingpin is not properly reinstalled, the trucks will fail to perform properly.
  4. Longboard or Skateboard Truck Maintenance: passo 4, immagine 1 di 1
    • Remove the truck raiser if applicable.
  5. Longboard or Skateboard Truck Maintenance: passo 5, immagine 1 di 2 Longboard or Skateboard Truck Maintenance: passo 5, immagine 2 di 2
    • Remove the bolts from the factory drilled holes on the deck.
    • Note that the bolts are small and easy to lose track of.
  6. Longboard or Skateboard Truck Maintenance: passo 6, immagine 1 di 1
    • Clean the deck with a moist cloth or cleaning solution.
  7. Longboard or Skateboard Truck Maintenance: passo 7, immagine 1 di 1
    • Clean the trucks with a moist cloth or cleaning solution.
  8. Longboard or Skateboard Truck Maintenance: passo 8, immagine 1 di 2 Longboard or Skateboard Truck Maintenance: passo 8, immagine 2 di 2
    • Clean the hardware by either soaking it in cleaning solution, or by manually cleaning it with a moist cloth.
  9. Longboard or Skateboard Truck Maintenance: passo 9, immagine 1 di 1
    • Repeat steps 1-7 with the second truck.
  10. Longboard or Skateboard Truck Maintenance: passo 10, immagine 1 di 1
    • After re-installation, check and confirm that all the bolts and nuts are tight. The bolts should be slightly submerged in the wood of the deck
    • Over tightening the bolts can cause them to strip.
    • Failure to tighten the bolts and nuts properly may lead to improper performance.
  11. Longboard or Skateboard Truck Maintenance: passo 11, immagine 1 di 2 Longboard or Skateboard Truck Maintenance: passo 11, immagine 2 di 2
    • After re-installing the trucks, check and confirm the kingpin is facing outward.
    • Failure to do this will cause the longboard's functions to be inverted, which may lead to personal injury.
Conclusione
Now you’ve completed the guide ‘How to clean and maintain skate/longboard trucks. Your longboard should look like the picture. Before riding, as a final precaution, make sure every piece is securely fastened and the trucks are facing the correct way. Have fun and always wear a helmet!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 7,417
