Introduzione
Disassemble your Logitech VX Nano Wireless Mouse to either replace your broken scroll wheel or clean your current one.
Cosa ti serve
Pull down on the battery release tab to remove the battery cover.
Remove battery cover.
Use a Phillips #1 screwdriver to remove the two 6 mm-long screws at the bottom of the battery compartment.
Insert an opening pick underneath the corner of one of the adhesive skates.
Continue to push the opening pick between the adhesive pad and the mouse case, slowly working the adhesive away from the case.
Repeat this same process for the two other skates.
Use the flat end of a spudger to carefully pry one side of the scroll wheel out of its clear plastic housing.
Use a set of tweezers to grasp either side of the scroll wheel near the axle. Use one side of the tweezers to keep the scroll wheel from popping back into the clear plastic housing on the side you already disconnected.
At the same time, use the other side of the tweezers to pull the opposite side of the scroll wheel loose from the clear plastic housing.
Altre 3 persone hanno completato questa guida.
2 Commenti
Thanks for the instruction!
Although I think it is impossible to remove the skates (pads, feet, whatever you call them) without damaging them.
But the replacement is still relatively easy to find on Ali or ebay.
You’re totally right! I’ll add this clarification to the step. Thanks!
