Introduzione
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom power button.
Cosa ti serve
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Locate the end of the speaker which contains the power button.
Grasp the outer rim of this end cap and pull in an upward motion.
Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
Using your fingers lift the board out of place.
