Salta al contenuto principale
Logitech UE MegaBoom 3 Battery Replacement
Cosa ti serve
    1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: passo 1, immagine 1 di 2 Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: passo 1, immagine 2 di 2
      • To access all internal components, first flip the speaker upwards to where you can see the base.
      • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech UE MegaBoom 3 Battery Replacement: passo 2, immagine 1 di 3 Logitech UE MegaBoom 3 Battery Replacement: passo 2, immagine 2 di 3 Logitech UE MegaBoom 3 Battery Replacement: passo 2, immagine 3 di 3
      • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
      • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
      • Pry off the base of the speaker and remove the end cap.
      Chiedi a FixBot
      Aggiungi Commento
    1. Logitech UE MegaBoom 3 Battery Replacement, Battery: passo 3, immagine 1 di 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: passo 3, immagine 2 di 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: passo 3, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Remove the lithium-ion battery from the inside of the speaker by gripping the battery using the plyers.
      • Here, it is ideal to use a tweezers as opposed to the plyers, however, the plyers makes it so much easier to take out the battery.
      • The battery should slide out as you pull against it with the plyers.
      • Remove the battery.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 90
Ultimi 30 giorni: 297
Tutti i Tempi: 4,249
