Salta al contenuto principale
Logitech UE Boombox Speaker Grille Replacement
Cosa ti serve
  1. Logitech UE Boombox Speaker Grille Replacement, Speaker Grille: passo 1, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement, Speaker Grille: passo 1, immagine 2 di 2
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Speaker Grille Replacement: passo 2, immagine 1 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 2, immagine 2 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 2, immagine 3 di 3
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Speaker Grille Replacement: passo 3, immagine 1 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 3, immagine 2 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 3, immagine 3 di 3
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Speaker Grille Replacement: passo 4, immagine 1 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 4, immagine 2 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 4, immagine 3 di 3
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Speaker Grille Replacement: passo 5, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement: passo 5, immagine 2 di 2
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Speaker Grille Replacement: passo 6, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement: passo 6, immagine 2 di 2
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Speaker Grille Replacement: passo 7, immagine 1 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 7, immagine 2 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 7, immagine 3 di 3
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Speaker Grille Replacement: passo 8, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement: passo 8, immagine 2 di 2
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Speaker Grille Replacement: passo 9, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement: passo 9, immagine 2 di 2
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Speaker Grille Replacement: passo 10, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement: passo 10, immagine 2 di 2
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Speaker Grille Replacement: passo 11, immagine 1 di 2 Logitech UE Boombox Speaker Grille Replacement: passo 11, immagine 2 di 2
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Speaker Grille Replacement: passo 12, immagine 1 di 1
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Speaker Grille Replacement: passo 13, immagine 1 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 13, immagine 2 di 3 Logitech UE Boombox Speaker Grille Replacement: passo 13, immagine 3 di 3
    • Pull vertically on the speaker grille to remove it from the boombox.
Conclusione
tyler hua
Membro da: 09/15/16
253 Reputazione
1 Guida realizzata
CSU Fullerton, Team 1-1, Bruce Fall 2016 Membro di CSU Fullerton, Team 1-1, Bruce Fall 2016
CSUF-BRUCE-F16S1G1
4 Membri
5 Guide realizzate
Un commento
Awesome guide thanks. Had to strip mine down as it stopped working, replugged it all and it’s good as new. Knowing how it’s down saves brute force and ignorance :)
matt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 935
