Salta al contenuto principale
Logitech UE Boombox Bluetooth Adapter Replacement
Cosa ti serve
  1. Logitech UE Boombox Bluetooth Adapter Replacement, Speaker Grille: passo 1, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement, Speaker Grille: passo 1, immagine 2 di 2
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Bluetooth Adapter Replacement: passo 2, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 2, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 2, immagine 3 di 3
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Bluetooth Adapter Replacement: passo 3, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 3, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 3, immagine 3 di 3
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Bluetooth Adapter Replacement: passo 4, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 4, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 4, immagine 3 di 3
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Bluetooth Adapter Replacement: passo 5, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement: passo 5, immagine 2 di 2
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Bluetooth Adapter Replacement: passo 6, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement: passo 6, immagine 2 di 2
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Bluetooth Adapter Replacement: passo 7, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 7, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 7, immagine 3 di 3
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Bluetooth Adapter Replacement: passo 8, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement: passo 8, immagine 2 di 2
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Bluetooth Adapter Replacement: passo 9, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement: passo 9, immagine 2 di 2
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Bluetooth Adapter Replacement: passo 10, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement: passo 10, immagine 2 di 2
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Bluetooth Adapter Replacement: passo 11, immagine 1 di 2 Logitech UE Boombox Bluetooth Adapter Replacement: passo 11, immagine 2 di 2
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Bluetooth Adapter Replacement: passo 12, immagine 1 di 1
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Bluetooth Adapter Replacement: passo 13, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 13, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 13, immagine 3 di 3
    • Pull vertically on the speaker grille to remove it from the boombox.
  14. Logitech UE Boombox Bluetooth Adapter Replacement, Bluetooth Adapter: passo 14, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement, Bluetooth Adapter: passo 14, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement, Bluetooth Adapter: passo 14, immagine 3 di 3
    • Remove the fifteen 13.0mm Phillips #2 screws from the side of the device containing two speakers.
    • Separate the two halves by gently pulling them apart.
    • The screws at this step are embedded deep within the device so make sure your screwdriver is long.
  15. Logitech UE Boombox Bluetooth Adapter Replacement: passo 15, immagine 1 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 15, immagine 2 di 3 Logitech UE Boombox Bluetooth Adapter Replacement: passo 15, immagine 3 di 3
    • Pull up on the lock connecting the band connector to the motherboard with your finger tips.
    • Detach the band connector gently from the motherboard.
  16. Logitech UE Boombox Bluetooth Adapter Replacement: passo 16, immagine 1 di 1
    • Remove the five black 7.0mm Phillips #2 screws.
  17. Logitech UE Boombox Bluetooth Adapter Replacement: passo 17, immagine 1 di 1
    • Move the motherboard away from bluetooth adapter gently.
    • Remove two 7.0mm Phillips #2 screws.
    • Motherboard will still be attached to device.
  18. Logitech UE Boombox Bluetooth Adapter Replacement: passo 18, immagine 1 di 1
    • Remove the bluetooth adapter from the boombox.
Conclusione
CSU Fullerton, Team 1-1, Bruce Fall 2016 Membro di CSU Fullerton, Team 1-1, Bruce Fall 2016
CSUF-BRUCE-F16S1G1
4 Membri
5 Guide realizzate
1Commento della guida
I need a new bluetooth adapter for my ue boombox. Where can i get one
Ragnar Teinburg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,873
