Cosa ti serve
Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
Finally, after opening the speaker, locate the USB plate on the left face of the speaker and remove it from the motherboard.
Altre 9 persone hanno completato questa guida.
12 Commenti
Hello,
does anyone know where to get new usb port, the logitech support didnĀ“t really help.
cheers marius
Same question as above, where can i buy a replacement USB port?
i found 10 of them on ebay for 3-4 dollars
Hi there , can you give me a link to Ebay where to find this port, thanks
can you send me a link on ebay where to find this replacement port , thanks
