Salta al contenuto principale
Logitech Pure-Fi Anywhere 2 Battery Replacement
Cosa ti serve
  1. Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: passo 1, immagine 1 di 2 Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: passo 1, immagine 2 di 2
    • To avoid damage to the outside of the casing create a first opening with a plastic opening tool.
    • Insert the metal spudger in the opening you just created.
  2. Logitech Pure-Fi Anywhere 2 Battery Replacement: passo 2, immagine 1 di 2 Logitech Pure-Fi Anywhere 2 Battery Replacement: passo 2, immagine 2 di 2
    • Now work your way along all sides, cuting through the glue with the spudger. The glue is all over so make make sure to go deep enough under the cover with the spudger.
  3. Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: passo 3, immagine 1 di 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: passo 3, immagine 2 di 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: passo 3, immagine 3 di 3
    • Remove the plastic cover to get access to the screws.
    • The glue will still stick when reassambling the Pure-Fi Anywhere.
  4. Logitech Pure-Fi Anywhere 2 Battery Replacement, Unscrew front cover: passo 4, immagine 1 di 1
    • Remove the eight Phillips screws securing the front cover to the back cover.
  5. Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: passo 5, immagine 1 di 2 Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: passo 5, immagine 2 di 2
    • Lift the front cover up away from the back cover. Do not pull them apart too far though as the battery is secured to the back cover while everything else is secured to the front cover.
    • Chances are that the wires running from the battery itself to the connector are firmly tucked behind the battery making it hard to get a grip on the connecter so just leave it connected for now.
  6. Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: passo 6, immagine 1 di 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: passo 6, immagine 2 di 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: passo 6, immagine 3 di 3
    • Remove the two Phillips screws securing the battery cover.
    • Remove the battery cover to finaly get access to the battery.
    • Now you can get a good grip on the battery connector to disconnect it.
    • Replace with new battery!
  7. Logitech Pure-Fi Anywhere 2 Battery Replacement: passo 7, immagine 1 di 1
    • Chances are your replacement battery doesn't have foam tape taped around it. If you don't have a roll of foam tape lying around at home just gently peel off the tape from the old battery and aply it to the new battery. This will ensure that the battery will firmly be secured under the battery cover.
Conclusione
Altre 19 persone hanno completato questa guida.
EricV
Membro da: 08/01/15
818 Reputazione
2 Guide realizzate
6Commenti sulla guida
Excellent guide. Thanks for taking the trouble to include numerous pictures - it makes all the difference. I found separating the glue from the cover was a bit daunting but once apart the rest was easy.
Andrew - Replica
FANTASTIC!!
this really helped me resurect one of my favourite Products which would have otherwise ended up in the trash!
chris - Replica
Amazing bro, i was suspecting that could be the way of doing it, but was too afraid of breaking it.
rodri_opomoz - Replica
Worked for me! Good guide. BTW: the speaker has amazing sound
David Lai - Replica
Good guide. I did not want to spend $14.00 for a battery. I took apart an old hp laptop battery which has 6 cells in it. Checked and they were not completely dead. Removed 2 cells ( I have 2 of these iPod docks). Soldered the small control board/ harness to the “new” cells. Works. Getting a little over 4hrs played at second loudest volume. Good enough. Have 2 working units for zero cost. Just ordered a Bluetooth iPod adapter ($4.60) so I can be full wireless. Really good sound too.
Steve Solorio - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 98
Tutti i Tempi: 11,356
