Salta al contenuto principale
Logitech MX Mechanical Mini Akku tauschen
Cosa ti serve
  1. Logitech MX Mechanical Mini Akku tauschen, Akku: passo 1, immagine 1 di 1
    • Entferne den Aufkleber auf der Rückseite des Gerätes in Höhe der linken unteren Ecke.
    • Tue das gleiche mit der rechten Ecke.
  2. Logitech MX Mechanical Mini Akku tauschen: passo 2, immagine 1 di 1
    • Sei vorsichtig beim Ausbau der Klappe, da die 3 Halter leicht abbrechen können.
  3. Logitech MX Mechanical Mini Akku tauschen: passo 3, immagine 1 di 1
    • Ziehe das Kabel ab.
  4. Logitech MX Mechanical Mini Akku tauschen: passo 4, immagine 1 di 1
    • Der Akku ist mit doppelseitigem Klebeband am Gehäuse befestigt. Hebe ihn vorsichtig mit einem Spatel oder breiten Schraubendreher ab.
Conclusione
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Altre 2 persone hanno completato questa guida.
4Commenti sulla guida
Thank you for posting this. I just picked this keyboard up today and decided to watch a disassembly video on YouTube during which the individual reported that the battery was sealed into the back plate of the keyboard which caused me to consider returning it to the store. Clearly he didn't look under the label. Glad to see it's at least serviceable!
Jared S. - Replica
Thanks for posting this. This guide also works for the MX Mechanical full-sized keyboard.
Francis Bell - Replica
Where'd you find the replacement battery? Google search only seems to turn up some sketchy looking sites.
Christopher Larrieu - Replica
Location dimensions are 8,5 x 5 x 0,5 cm.
gaMiNOos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 148
Tutti i Tempi: 3,183
