Salta al contenuto principale
Logitech MBJ58 Mouse Support Spring Replacement
Cosa ti serve
  1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: passo 1, immagine 1 di 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech MBJ58 Mouse Support Spring Replacement: passo 2, immagine 1 di 2 Logitech MBJ58 Mouse Support Spring Replacement: passo 2, immagine 2 di 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 1 di 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 2 di 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 3 di 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: passo 4, immagine 1 di 2 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: passo 4, immagine 2 di 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: passo 5, immagine 1 di 2 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: passo 5, immagine 2 di 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 5-14, Forte Winter 2013 Membro di Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membri
23 guide realizzate
1Commento della guida
The thing with the spring - still in 2024 helpful!
Thanks a lot! :-)
Michaela Meyer - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 78
Tutti i Tempi: 5,214
