Salta al contenuto principale
Logitech MBJ58 Mouse Buttons Replacement
Cosa ti serve
  1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: passo 1, immagine 1 di 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Logitech MBJ58 Mouse Buttons Replacement: passo 2, immagine 1 di 2 Logitech MBJ58 Mouse Buttons Replacement: passo 2, immagine 2 di 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Logitech MBJ58 Mouse Buttons Replacement, Buttons: passo 3, immagine 1 di 2 Logitech MBJ58 Mouse Buttons Replacement, Buttons: passo 3, immagine 2 di 2
    • Locate the two tabs that are protruding from the button assembly.
    • Be careful not to break either of the two tabs by squeezing too hard.
    • Pinch the tabs together to free the buttons.
  4. Logitech MBJ58 Mouse Buttons Replacement: passo 4, immagine 1 di 2 Logitech MBJ58 Mouse Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
    • Slide the button assembly out from the top cover through the opening.
    • When fully disassembled, the top cover and the button assembly should look like this.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 5-14, Forte Winter 2013 Membro di Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membri
23 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 65
Tutti i Tempi: 3,371
