Salta al contenuto principale
Logitech MBJ58 Mouse Button Replacement
Cosa ti serve
  1. Logitech MBJ58 Mouse Button Replacement, Mouse button: passo 1, immagine 1 di 1
    • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
    • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
    • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
    • Loosen the Phillips screw in the bottom.
    • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
    • The motherboard is just plugged in and can be carefully removed forwards and upwards.
    • Sensibly, first clean everything (dry).
    • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
    • Everything should click together again and screws can be screwed back in. -> Loooift.
Conclusione
Repeat the steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Tho. Hummet
Membro da: 04/05/18
121 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 496
