Salta al contenuto principale
Logitech M535 Disassembly
Cosa ti serve
  1. Logitech M535 Disassembly, Logitech M535: passo 1, immagine 1 di 1
    • This is how the mouse looks like once fixed
  2. Logitech M535 Disassembly, Open the battery box: passo 2, immagine 1 di 1
    • Slide the cover open to get to the battery
  3. Logitech M535 Disassembly: passo 3, immagine 1 di 1
    • Pull the sticker inside of the battery box slowly: the glue is pretty strong and the space is tight. A butter knife works alright. You need to remove enough of the sticker to get to the bottom of the battery box.
  4. Logitech M535 Disassembly: passo 4, immagine 1 di 1
    • The little screw is approximately there (it occurred to me I should write a guide only after I closed the mouse).
    • Gently pull apart the top and the bottom at this stage with some care to avoid breaking the internal plastic.
Conclusione
Altre 4 persone hanno completato questa guida.
Sam Curti
Membro da: 03/19/19
239 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 105
Tutti i Tempi: 2,750
