Salta al contenuto principale
Introduzione
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Parti
  1. Remove the battery hatch and batteries.
    • Remove the battery hatch and batteries.
  2. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  3. Remove the single Phillips screw located between the battery sockets.
    • Remove the single Phillips screw located between the battery sockets.
  4. Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Conclusione
Altre 4 persone hanno completato questa guida.
Anna Sweetnam
Membro da: 08/04/2010
232 Reputazione
1 Guida realizzata
I got to step 3. where is step 4?
hawaii50 - Replica
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Replica
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Replica
M545 works similarly btw
Adri Idzwan Mansor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,406
