Introduzione
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Parti
Remove the battery hatch and batteries.
  • Remove the battery hatch and batteries.
Aggiungi Commento
Remove the single Phillips screw located between the battery sockets.
  • Remove the single Phillips screw located between the battery sockets.
I used this guide to open my Logitech M-RCQ142 (that looks almost the same). Logitech changed the one screw-system to four screws located in the same place, so this guide worked perfect. Thanks for sharing!
WillemPirquin - Replica
  • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
doesn't go deep enough. need to fix right switch. part numbers are required.
Lewayne Gragert - Replica
I doubt you can get parts for this, it's not a high ticket item.
Anna Sweetnam - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
Anna Sweetnam
Membro da: 08/04/2010
232 Reputazione
1 Guida realizzata
I got to step 3. where is step 4?
hawaii50 - Replica
What are you trying to do? All of the innards are available once step 3 is complete.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 39
Tutti i Tempi: 3,021
