Salta al contenuto principale
Logitech M515 (Couch) Mouse
Cosa ti serve
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: passo 1, immagine 1 di 1
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: passo 2, immagine 1 di 1
    • Remove the single Phillips screw located between the battery sockets.
  3. Logitech M515 (Couch) Mouse: passo 3, immagine 1 di 1
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Conclusione
Altre 4 persone hanno completato questa guida.
Anna Sweetnam
Membro da: 04/08/10
232 Reputazione
1 Guida realizzata
4 Commenti
I got to step 3. where is step 4?
hawaii50 - Replica
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Replica
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Replica
M545 works similarly btw
Adri Idzwan Mansor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,918
