Salta al contenuto principale
Logitech M310 Mouse Wheel Spring Repair
Cosa ti serve
  1. Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: passo 1, immagine 1 di 2 Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: passo 1, immagine 2 di 2
    • Check if the scroll wheel is spinning freely without resistance.
    • A correctly aligned spring will cause the wheel to ratchet in small increments
  2. Logitech M310 Mouse Wheel Spring Repair: passo 2, immagine 1 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 2, immagine 2 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 2, immagine 3 di 3
    • Use your thumb to press the indentation on the bottom battery cover.
    • Slide down the battery cover and fully remove the battery cover.
    • Remove the battery.
  3. Logitech M310 Mouse Wheel Spring Repair: passo 3, immagine 1 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 3, immagine 2 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 3, immagine 3 di 3
    • Remove two Phillips #1 screws.
  4. Logitech M310 Mouse Wheel Spring Repair: passo 4, immagine 1 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 4, immagine 2 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 4, immagine 3 di 3
    • Remove the bottom board plate from the mouse body by pulling it down and away.
    • Ensure not to apply the force perpendicular to the mouse body. The board will only remove in a downward direction.
  5. Logitech M310 Mouse Wheel Spring Repair: passo 5, immagine 1 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 5, immagine 2 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 5, immagine 3 di 3
    • Use the 2mm flat head to lift up the spring leg.
    • Use the screwdriver as a lever to pry the spring leg back into the scroll wheel
    • You may need to use your thumb to pull the scroll wheel to the left a few millimeters, creating enough of a gap on the right side for the spring leg to fit into the mouse wheel cavity.
    • The spring leg should no longer be visible once aligned inside the mouse wheel cavity.
  6. Logitech M310 Mouse Wheel Spring Repair: passo 6, immagine 1 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 6, immagine 2 di 3 Logitech M310 Mouse Wheel Spring Repair: passo 6, immagine 3 di 3
    • Before reassembling the mouse, confirm if the scroll wheel is fixed appropriately.
    • Gently place the mouse down on the table and scroll the wheel. There should now be a noticeable difference in resistance, and it should no longer freely spin.
    • If the scroll wheel is still not fixed, you may need to readjust the spring into the cavity again (see Step 5).
Conclusione
Altre 8 persone hanno completato questa guida.
UC Davis, Team S2-G2, Andersen Winter 2020 Membro di UC Davis, Team S2-G2, Andersen Winter 2020
UCD-ANDERSEN-W20S2G2
4 Membri
2 Guide realizzate
7 Commenti
Great tutorial. I thought I needed to buy another one. With this I managed to fix it under 2 minutes. Thanks! :)
StopShop GSM - Replica
Excellent instructions, I searched the web for days looking for the solution. I could not determine if it was software or hardware, the mouse wheel has always spun free, no clicking. After following your instructions, it clicks when I scroll and the spontaneous jumping is gone. Thanks a million!
Bob Weenig - Replica
Fantastic instructions! I was struggling to find out how the spring should be placed for the proper ratcheting behavior. This walk-through got me there in less than a minute. Thank you very much!
Sean Smith - Replica
Is there any way to replace the spring if lost?
Connor - Replica
Thanks so much for the great tutorial. The pictures really helped.
Maureen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 194
Tutti i Tempi: 7,580
