Salta al contenuto principale
Logitech M215 Lens Replacement
Cosa ti serve
  1. Logitech M215 Lens Replacement, Remove the battery cover: passo 1, immagine 1 di 3 Logitech M215 Lens Replacement, Remove the battery cover: passo 1, immagine 2 di 3 Logitech M215 Lens Replacement, Remove the battery cover: passo 1, immagine 3 di 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    The battery lid lifts up from the back. It does not slide back.
    Bob Peters - Replica
    U need to keep clean…& battery compartment needs gently pried off. Make sure to put back lid cover, pushing down on black prong..OR will not make contact.
    cconradmoore - Replica
    Thanks to u, i succeeded
    aresa0519 - Replica
  2. Logitech M215 Lens Replacement, Remove old battery: passo 2, immagine 1 di 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    After replacing battery light goes on then off. I tried it twice. Do I need a new part.
    Elsie Sarkisian - Replica
    After replacing battery the remote green light goes on then off. I tried it twice
    What do u mean reverse order?
    The laser light did not go on
    Thank you this worked nicely
    - Reworld - - Replica
    Thanks for this!
    Tiara Dubb - Replica
  3. Logitech M215 Lens Replacement, Top Cover: passo 3, immagine 1 di 2 Logitech M215 Lens Replacement, Top Cover: passo 3, immagine 2 di 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Lens Replacement: passo 4, immagine 1 di 1
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Lens Replacement, Motherboard: passo 5, immagine 1 di 2 Logitech M215 Lens Replacement, Motherboard: passo 5, immagine 2 di 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
  6. Logitech M215 Lens Replacement, Lens: passo 6, immagine 1 di 2 Logitech M215 Lens Replacement, Lens: passo 6, immagine 2 di 2
    • The laser amplifier is not connected to the rest of the mouse and can simply be removed at this point.
Conclusione
Hannah Pate
Membro da: 01/30/15
1.734 Reputazione
7 Guide realizzate
USF Tampa, Team 1-1, Watkins Winter 2015 Membro di USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Membri
28 Guide realizzate
Un commento
Where i can buy mouse lenses for mk225
Cybermetz X - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,885
