Salta al contenuto principale
Logitech M215 Cover Release Button Replacement
Cosa ti serve
  1. Logitech M215 Cover Release Button Replacement, Remove the battery cover: passo 1, immagine 1 di 3 Logitech M215 Cover Release Button Replacement, Remove the battery cover: passo 1, immagine 2 di 3 Logitech M215 Cover Release Button Replacement, Remove the battery cover: passo 1, immagine 3 di 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Cover Release Button Replacement, Remove old battery: passo 2, immagine 1 di 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Cover Release Button Replacement, Top Cover: passo 3, immagine 1 di 2 Logitech M215 Cover Release Button Replacement, Top Cover: passo 3, immagine 2 di 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Cover Release Button Replacement: passo 4, immagine 1 di 1
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Cover Release Button Replacement, Motherboard: passo 5, immagine 1 di 2 Logitech M215 Cover Release Button Replacement, Motherboard: passo 5, immagine 2 di 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
  6. Logitech M215 Cover Release Button Replacement, Cover Release Button: passo 6, immagine 1 di 3 Logitech M215 Cover Release Button Replacement, Cover Release Button: passo 6, immagine 2 di 3 Logitech M215 Cover Release Button Replacement, Cover Release Button: passo 6, immagine 3 di 3
    • Unscrew the 0.25mm phillips head screw holding the button in place. The cover release button can then be removed.
Conclusione
Altre 2 persone hanno completato questa guida.
Hannah Pate
Membro da: 01/30/15
1.742 Reputazione
7 Guide realizzate
USF Tampa, Team 1-1, Watkins Winter 2015 Membro di USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Membri
28 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,529
