Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Logitech K700 Keyboard, usa il nostro manuale di assistenza.
  1. Logitech K700 Keyboard Teardown, Logitech K700 Keyboard Teardown: passo 1, immagine 1 di 1
    • Turn the keyboard over and slide the battery cover in the direction of the arrows slightly, and then lift the cover away.
  2. Logitech K700 Keyboard Teardown: passo 2, immagine 1 di 1
    • Remove the batteries and the two screws shown.
  3. Logitech K700 Keyboard Teardown: passo 3, immagine 1 di 1
    • Use a thumbnail or a pick to separate the clips around the periphery between the black and white plastic parts.
    • There are 4 clips on the top, 2 on either side, and 5 along the bottom. If you do the sides and top first, the bottom should slide out.
    • Don't separate the top and bottom immediately, since there are a couple of cables (near the touch pad) that connect between the two.
  4. Logitech K700 Keyboard Teardown: passo 4, immagine 1 di 1
    • The smaller of the two cables is for the touchpad. Lift the catch on its connector in order to slide it out.
    • The larger cable is for the key matrix. Just pull it out from the connector (friction fit).
    • This is as far as you can easily disassemble the keyboard. To go further requires removing 12 screws and 35 plastic rivets. This is not recommended.
    • To clean the keyboard of liquid, I suggest holding it over a sink with the touchpad side up, then spraying plenty of isopropyl alcohol from the back, avoiding the touch-pad area (you may wish to mask it off). Let dry completely before reassembling.
    • If keys still do not function after cleaning, then it is possible that traces on the key matrix have become corroded. This is not repairable, since the key matrix is a sealed unit. It consists of 3 layers of plastic that are sealed together. Unfortunately, it is not 100% sealed to prevent entry of liquids.
  5. Logitech K700 Keyboard Teardown: passo 5, immagine 1 di 1
    • Should you go further and remove the 12 screws and 35 plastic rivets, you can see this.
  6. Logitech K700 Keyboard Teardown: passo 6, immagine 1 di 1
    • The keys can be popped out easily enough by pushing from the back side. This exposes the key matrix.
  7. Logitech K700 Keyboard Teardown: passo 7, immagine 1 di 1
    • Here is the key matrix in all its glory.
cityzen
Membro da: 05/03/10
4.117 Reputazione
2 Guide realizzate
3Commenti sulla guida
Very helpful! I combined this and cleaning the battery compartments with a white vinegar drenched Q-Tip to clean out some old battery corrosion, and now it turns on!
mpeterfin - Replica
any way you could send me a pic of the backside of the battery cover? i’d like to try to recreate it with a 3d printer
Cody Nelson - Replica
codycnelson@gmail.com :)
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 52
Tutti i Tempi: 16,709
