Salta al contenuto principale
Logitech Harmony Ultimate Charging Station Motherboard Replacement
Cosa ti serve
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: passo 1, immagine 1 di 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: passo 1, immagine 2 di 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: passo 1, immagine 3 di 3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 2, immagine 1 di 2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 3, immagine 1 di 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 3, immagine 2 di 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 4, immagine 1 di 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 4, immagine 2 di 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 4, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Conclusione
USF Tampa, Team 8-1, Eyestone Fall 2015 Membro di USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Membri
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,063
