Salta al contenuto principale
Logitech Harmony Touch Power Adapter Replacement
Cosa ti serve
  1. Logitech Harmony Touch Power Adapter Replacement, Power Adapter: passo 1, immagine 1 di 1
    • Open the latch that assesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screwdriver.
  2. Logitech Harmony Touch Power Adapter Replacement: passo 2, immagine 1 di 2 Logitech Harmony Touch Power Adapter Replacement: passo 2, immagine 2 di 2
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out when opening.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  3. Logitech Harmony Touch Power Adapter Replacement: passo 3, immagine 1 di 1
    • Once your device is open, check to see if wires are intact.
    • If wires are not intact, solder your wires back in place to ensure contact with your charging port.
Conclusione
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 710
