Salta al contenuto principale
Logitech Harmony Touch Motherboard Replacement
Cosa ti serve
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: passo 2, immagine 1 di 3 Logitech Harmony Touch Motherboard Replacement: passo 2, immagine 2 di 3 Logitech Harmony Touch Motherboard Replacement: passo 2, immagine 3 di 3
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Conclusione
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 726
