Salta al contenuto principale
Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement
Cosa ti serve
  1. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Back Panel: passo 1, immagine 1 di 2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Back Panel: passo 1, immagine 2 di 2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 2, immagine 1 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 2, immagine 2 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 2, immagine 3 di 3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 3, immagine 1 di 1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 4, immagine 1 di 2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 4, immagine 2 di 2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 5, immagine 1 di 2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 5, immagine 2 di 2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 6, immagine 1 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 6, immagine 2 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 6, immagine 3 di 3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 7, immagine 1 di 2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 7, immagine 2 di 2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 8, immagine 1 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 8, immagine 2 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 8, immagine 3 di 3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 9, immagine 1 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 9, immagine 2 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 9, immagine 3 di 3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: passo 10, immagine 1 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: passo 10, immagine 2 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: passo 10, immagine 3 di 3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  11. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 11, immagine 1 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 11, immagine 2 di 3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: passo 11, immagine 3 di 3
    • Grip the other lower end of the ribbon flex cable using your thumb and index finger.
    • Gently slide the cable up and out of the green card.
Conclusione
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Membro di CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Membri
10 Guide realizzate
Un commento
Where can I get a replacement flex ribbon cable, the same as shown here?
Eman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 877
