Salta al contenuto principale
Logitech Harmony Companion Remote Battery Replacement
Cosa ti serve
  1. Logitech Harmony Companion Remote Battery Replacement, Remote Battery: passo 1, immagine 1 di 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Battery Replacement: passo 2, immagine 1 di 1
    • Push the battery cover upward.
    MY Logitech Harmony smart control does NOT have a battery door. There is absolutely no way to get to any battery HELP
    ussscamp - Replica
  3. Logitech Harmony Companion Remote Battery Replacement: passo 3, immagine 1 di 3 Logitech Harmony Companion Remote Battery Replacement: passo 3, immagine 2 di 3 Logitech Harmony Companion Remote Battery Replacement: passo 3, immagine 3 di 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
3 Commenti
Article fails without mentioning the type of battery the remote uses.
Dave Rombeck - Replica
The battery type is CR2032 3v Lithium coin/button cell
Harmeet Tatla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 124
Tutti i Tempi: 25,167
