Salta al contenuto principale
Logitech Harmony Companion Harmony Hub Motherboard Replacement
Cosa ti serve
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: passo 1, immagine 1 di 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: passo 1, immagine 2 di 2
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 2, immagine 1 di 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 3, immagine 1 di 1
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 4, immagine 1 di 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 4, immagine 2 di 2
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, immagine 1 di 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, immagine 2 di 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, immagine 3 di 3
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
Conclusione
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 541
