Salta al contenuto principale
Logitech Harmony Companion Button Pad Replacement
Cosa ti serve
  1. Logitech Harmony Companion Button Pad Replacement, Remote Battery: passo 1, immagine 1 di 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Button Pad Replacement: passo 2, immagine 1 di 1
    • Push the battery cover upward.
  3. Logitech Harmony Companion Button Pad Replacement: passo 3, immagine 1 di 3 Logitech Harmony Companion Button Pad Replacement: passo 3, immagine 2 di 3 Logitech Harmony Companion Button Pad Replacement: passo 3, immagine 3 di 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: passo 4, immagine 1 di 2 Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: passo 4, immagine 2 di 2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Button Pad Replacement: passo 5, immagine 1 di 2 Logitech Harmony Companion Button Pad Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Button Pad Replacement: passo 6, immagine 1 di 2 Logitech Harmony Companion Button Pad Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool to remove the motherboard.
  7. Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, immagine 1 di 3 Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, immagine 2 di 3 Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, immagine 3 di 3
    • Lift the button pad up to remove it from the remote.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
4Commenti sulla guida
Ou pouvons nous commander «  Logitech Harmony Companion Button Pad Replacement »
Roger Tardif - Replica
Where can I purchase the button pad?
elijah - Replica
Also looking to find where to purchase. I called Logitech and they were clueless. My 4 year old was better equipped to respond.
Joshua Fuller - Replica
Thanks for posting these helpful steps. My harmony Companion was frustrating us because we had to press buttons really hard.
Cy Beaux - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,532
