Salta al contenuto principale
Logitech Harmony 950 Case Replacement
Cosa ti serve
  1. Logitech Harmony 950 Case Replacement, Battery: passo 1, immagine 1 di 2 Logitech Harmony 950 Case Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Case Replacement: passo 2, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 2, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Case Replacement: passo 3, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 3, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 3, immagine 3 di 3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Case Replacement: passo 4, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 4, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 4, immagine 3 di 3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
  5. Logitech Harmony 950 Case Replacement, Case: passo 5, immagine 1 di 3 Logitech Harmony 950 Case Replacement, Case: passo 5, immagine 2 di 3 Logitech Harmony 950 Case Replacement, Case: passo 5, immagine 3 di 3
    • Use the Phillips #1 screwdriver to remove the (3) three 6mm screws.
    • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
    • You need to repeat this process for both sides of the remote.
  6. Logitech Harmony 950 Case Replacement: passo 6, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 6, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
    • Use the Angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
  7. Logitech Harmony 950 Case Replacement: passo 7, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 7, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 7, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws. Keep in mind that once the screws are off, the circuit board will be completely separate from the case.
    • Be careful not to damage or disconnect the pink wires when removing the gold charging conductors from the case.
  8. Logitech Harmony 950 Case Replacement: passo 8, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 8, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 8, immagine 3 di 3
    • Remove the black tape to fully access the cable underneath.
    • This cable has a locking mechanism. Use the Angled Tweezers to lift the black part (lock).
    • Slide the yellow cable to disconnect it from the circuit board.
  9. Logitech Harmony 950 Case Replacement: passo 9, immagine 1 di 2 Logitech Harmony 950 Case Replacement: passo 9, immagine 2 di 2
    • Pull the circuit board off of the case. Start from the bottom, and lift up to completely detach it from the cover.
  10. Logitech Harmony 950 Case Replacement: passo 10, immagine 1 di 3 Logitech Harmony 950 Case Replacement: passo 10, immagine 2 di 3 Logitech Harmony 950 Case Replacement: passo 10, immagine 3 di 3
    • Use the Blunt Tweezers to carefully remove the keypad from the cover of the remote.
Conclusione
Altre 3 persone hanno completato questa guida.
Shiba Kandel
Membro da: 09/26/17
149 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G2, Passmore Fall 2017 Membro di USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Membri
4 Guide realizzate
3 Commenti
where can this casing be purchased?
Sharonda Bailey - Replica
Parts are required obviously!!
larrybud2004 - Replica
Is the usb bottom cap part of the replacement case? If not can u get one?
jmorrissette - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 58
Tutti i Tempi: 3,588
