Salta al contenuto principale
Logitech Harmony 900 Button Pad Replacement
Cosa ti serve
  1. Logitech Harmony 900 Button Pad Replacement, Battery: passo 1, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement, Battery: passo 1, immagine 2 di 2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. Logitech Harmony 900 Button Pad Replacement: passo 2, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement: passo 2, immagine 2 di 2
    • Push the battery in, pull it up, and slide it out.
  3. Logitech Harmony 900 Button Pad Replacement, Motherboard: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. Logitech Harmony 900 Button Pad Replacement: passo 4, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement: passo 4, immagine 2 di 2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. Logitech Harmony 900 Button Pad Replacement: passo 5, immagine 1 di 1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. Logitech Harmony 900 Button Pad Replacement: passo 6, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement: passo 6, immagine 2 di 2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. Logitech Harmony 900 Button Pad Replacement: passo 7, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement: passo 7, immagine 2 di 2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. Logitech Harmony 900 Button Pad Replacement: passo 8, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement: passo 8, immagine 2 di 2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. Logitech Harmony 900 Button Pad Replacement: passo 9, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement: passo 9, immagine 2 di 2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. Logitech Harmony 900 Button Pad Replacement: passo 10, immagine 1 di 1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
  11. Logitech Harmony 900 Button Pad Replacement, Button Pad: passo 11, immagine 1 di 2 Logitech Harmony 900 Button Pad Replacement, Button Pad: passo 11, immagine 2 di 2
    • Peel off the button pads from the device frame.
Conclusione
Tyler Hanks
Membro da: 09/25/17
442 Reputazione
3 Guide realizzate
USF Tampa, Team S4-G5, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S4G5
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 962
