Introduzione
It is recommended to have the iFixit ProTech toolkit and have already taken the case apart.
Cosa ti serve
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Attrezzo utilizzato in questo passaggio:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using the small end of a spudger, pry out the terminal from the interior of the case.
Altre 2 persone hanno completato questa guida.
