Salta al contenuto principale
Logitech G935 Partial Left-Side Disassembly
  1. Logitech G935 Partial Left-Side Disassembly, Remove the ear cup: passo 1, immagine 1 di 2 Logitech G935 Partial Left-Side Disassembly, Remove the ear cup: passo 1, immagine 2 di 2
    • Remove the ear cup. It is slightly elastic and may be gently stretched off, starting at one point and gently working around the perimeter. A spudger may help in both removal, and especially re-installation.
  2. Logitech G935 Partial Left-Side Disassembly, Open the section: passo 2, immagine 1 di 2 Logitech G935 Partial Left-Side Disassembly, Open the section: passo 2, immagine 2 di 2
    • Remove the 6 Phillips #0 screws retaining the top section.
    • Gently pull off the section you just unscrewed. Flipping it upside-down off to the side is a good bet.
    • Note there is a thin cable soldered to both halves. Be very gentle with this, as I suspect repair will be near-impossible. (It's surface-mounted on the PCB, and sealed inside the driver.)
  3. Logitech G935 Partial Left-Side Disassembly, Remove the speaker daughterboard: passo 3, immagine 1 di 2 Logitech G935 Partial Left-Side Disassembly, Remove the speaker daughterboard: passo 3, immagine 2 di 2
    • Remove the 2 screws holding the rear plastic facade that retains the buttons and volume wheel.
    • Carefully pull the daughterboard out. Note there is a plastic tab retaining it, but with the facade out of the way, the board is easily removed. Also note there is a ribbon cable attaching it to the mainboard.
    • Detach the ribbon cable from the daughterboard.
  4. Logitech G935 Partial Left-Side Disassembly, Remove the microphone daughterboard: passo 4, immagine 1 di 3 Logitech G935 Partial Left-Side Disassembly, Remove the microphone daughterboard: passo 4, immagine 2 di 3 Logitech G935 Partial Left-Side Disassembly, Remove the microphone daughterboard: passo 4, immagine 3 di 3
    • Remove the ribbon cable connecting the daughterboard to the mainboard.
    • Open the microphone to expose a hidden screw
    • Remove the screw retaining the front plastic facade.
    • The microphone will now come out. Take care as it's attached to the daughterboard via a small fragile soldered cable.
    • With the microphone out, remove the screw retaining the daughterboard.
    • Gently pry the daughterboard out. Prying from the curved section towards the screw (as the yellow arrow points) worked well for me.
    • Take care once the daughterboard is free, as it is still connected to the mainboard via soldered wires.
Conclusione
Altre 17 persone hanno completato questa guida.
Eric
Membro da: 11/23/20
620 Reputazione
1 Guida realizzata
5Commenti sulla guida
Thanks! It helped a lot. Mine was having a problem with the power on slider, I sprayed a little bit of contact cleaner and a little bit of rubbing with a soft brush, it's working like new now!
Eduardo H. Camargo - Replica
Thanks, gracias. Me ha ido bien para arreglar el boton de power que da ese sonido tan bugueao. Hay videos en youtube.
nickhell - Replica
I have a issue that i can move it from left to right a bit and the left ear isnt working at times until I fiddle with it, would this solve it ?
Ones i have sound it continues but every time i put it off i will have the same issue with the power slider.
deventer.pasman - Replica
At the very least getting a good view of the daughter board and the switch may give you other ideas as to what's going on. Good chance it's just the contacts inside the switch not making good contact, but cant hurt to clean up the daughter board if it seems to be dirty or corroded (one of mine was pretty corroded, not sure what happened to that one honestly). Once you have the daughter board out, you can take the metal cover off the switch mechanism and dismantle the switch to clean the internal contacts. Idk if I'm allowed to post links so we'll see if it lets me
This video is technically for the G933, not the G935, but the process of dismantling the switch mechanism itself is identical:
https://youtu.be/9r8KK3ynSQA?si=tTVSIBbN...
Be careful not to lose any of the little metal contacts when you clean it, but it's not terribly difficult.
Jeffrey Dwyer -
I'm having a similar issue - the left side hasn't worked in ages, everything looks fine, no corrosion or anything. Does anyone know how I can test if the speaker itself still works?
Lukas Nantz -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 244
Tutti i Tempi: 7,266
